Hi,
I just got my engine back from overhaul. My mechanic and I had to remove the oil sump to install the 150 exhaust bracket under the front sump nut. We have turned down a 7/16" socket almost paper thin and still can't get it on the nut to be able to tighten it fully. The sump nuts are MS21044N4 nuts. It seems like when I removed the exhaust bracket prior to the overhaul that the nuts were lower profile than the MS21044N4 nuts seems to be. Is there an acceptable lower profile nut I can use? My mechanic had all kinds of specially modified tools and none of them will work due to the super tight working space the exhaust bracket creates.
Josh
150 exhaust and front oil sump nut
- 8413
- Name: Josh C
- Aircraft Type: 140A/C90-14F
- IMG_3859.jpeg (553.54 KiB) Viewed 11421 times
Re: 150 exhaust and front oil sump nut
For the sump I prefer MS21042-4 nuts. They're all metal stop nuts and have a reduced size hex for easier installation in tight quarters.
Technically, nylon stop nuts shouldn't be used on an engine.
- Name: Josh C
Thanks John! That will make installation so much easier!
Josh
Josh
- 8413
- Name: Josh C
The MS21042-4 nut worked great! A standard (no modifications required) 5/16" universal drive socket did the trick. Thanks for your help John Cooper!
Josh
Josh
- Name: John G
- Are those cracks in the weld of the added support and the weld bead next to the nut on the oil tank?
- 8413
- Name: Josh C
8425,
If you are talking about the left support in the picture (right support if you are sitting in the pilots seat), I think those are shadows from the angle I was holding the light. I looked at the original picture and zoomed and they don't look like cracks to me. I will double check next time I'm at the hangar.
