Tailwheel Tilt
Tailwheel Tilt
This illustration is from the very comprehensive Neil Wright article on the tailwheel assembly and alignment. While I understand the vertical reference line, it's not clear what the tilted line is referenced against. Any help appreciated.
Re: Tailwheel Tilt
Try looking at it like this instead....
The top of the forks has a level plane that needs to be tilted backwards a little. This is my bird, this pic shows the slight tilt rear-ward. You want it to have a slight tilt rear-ward or pretty much level. Otherwise you get the 'shopping cart' wobble.
Here's a pic hopefully showing what we're trying to describe...
Re: Tailwheel Tilt
And here's an extreme view of the 'rear-ward' tilt, when I had the incorrect double-bend mainsprings on my bird. The tail was so much higher, I couldn't make a decent 3-point landing so I became a 'wheelie' guy.
Re: Tailwheel Tilt
Thanks for the quick reply - very helpful.
