firewall Rivets
monceaviation
Aircraft Type: 1946 140
Occupation-Interests: AP IA
firewall Rivets
Post by monceaviation »
Does anyone have the P/N for the Flat head rivets used on the fire wall?
Re: firewall Rivets
If you don't get an answer here, you can contact David Lowe through the members section on the main web page. David has the Cessna drawings that will list the correct rivet.
8425
Re: firewall Rivets
Post by 8425 »
Those rivets are AN442AD4-x. Univair has a small selection of sizes required. You will also need the proper rivet set. Rivets and the set are available with a Google search.
Re: firewall Rivets
Whenever we did firewall repairs (stainless steel or ternplate metal) we used monel rivets instead of aluminum rivets.
