WTB 140 Axle
Occupation-Interests: Aerospace Engineer, Autonomous Aircraft
WTB 140 Axle
Post by 8305 »
I need a single 140 axle for my rebuild project, as one of them was stolen.
8281
Re: WTB 140 Axle
Post by 8281 »
Hi,
I believe I have one. Will look and let U know today . Also check and let me know what size bolts hold the axle to the gear leg !
John
8305
Re: WTB 140 Axle
Post by 8305 »
Thanks. All four bolts are the same (smaller) size on the 140. I have a pile of later Cessna axles, but they use two different bolt sizes and won't work here.
8281
Re: WTB 140 Axle
Post by 8281 »
The axles that I have take AN5 Bolts ! ( 5/16 " )
John
Re: WTB 140 Axle
An AN5 bolt has roughly the same strength as a MS20004 bolt (NAS144). You can enlarge the bolt holes in the gear leg and use the AN5 bolts in place of the original setup. People do it all the time to install the sea plane axles. The axles are hard as all get out, though. An ordinary drill bit won't hold up very long.
