Fuel selector valve
atypicalguy
Fuel selector valve
Post by atypicalguy »
My tank selector valve seems to be leaking.A few drops into the belly. Is there an economical way to refurbish this valve
I see a rebuild kit listed for $700, but that seems exorbitant, so I'm hoping there's a cheaper option. Thanks Karl
Re: Fuel selector valve
Is it leaking from the shaft packing? If it's the original Imperial valve, there should be a leather packing under the big nut. You can try "rejuvenating" it with Fuel-lube (now EZ-Turn) or there's a post here somewhere about replacing it with a pair of O-rings. Years ago I fixed mine with one o-ring and a spacer, but the double o-ring idea sounds easier.
I am not aware of a repair kit. Do you have any more info?
Assuming it's the old brass on brass valve, left-right-off, then all you can try is drain all the fuel and remove the bonnet of the selector, clean and dab/smear just a little EZ Turn fuel lube on the truncated cone. Re-assemble. If the brass cone/seat is really scored you'll need to look into another valve (check UNIVAIR). There is a packing under the bonnet where the valve stem comes through. An M83248/1-109 o-ring is what I've been told. One member used a fat fuel injector o-ring Napa # 2-12085.
Use the SEARCH function on this forum and you'll get an earful. Here are a few useful links.
https://www.cessna120140.com/Forum2018/ ... f=10&t=131
https://www.cessna120140.com/Forum2018/ ... l+selector
https://www.univair.com/view-all/u04117 ... ts-cessna/
Here's an example of an original fuel selector Left-Right-Off so you can see what you are dealing with. Pretty simple. You don't need to remove the valve body from the aircraft to do the basic maintenance.
atypicalguy
Seems crazy that a simple three way valve could cost $686, but here it is from Aircraft Spruce:
https://www.aircraftspruce.com/catalog/ ... j4QAvD_BwE
It's $49 for the valve and $637 for the paperwork.
carsolha
Aircraft Type: 140,150,206
Occupation-Interests: A&P
Post by carsolha »
I was looking for a new valve too. I called Sierra Hotel Aero for one of the Cessna PMA valves. They don't have any but would be willing to get a batch if enough people show interest to make it less cost prohibitive. Anybody interested?
SHA200F202-120
https://www.sierrahotelaero.com/pma-sel ... alves.html
How many is "enough"?
carsolha
Post by carsolha »
He didn't say. Apparently my request was not "enough".
Aircraft Type: 140A/C90-14F
Post by 8413 »
I would be interested in the Sierra Hotel valve. I need the R,L,Both,Off version though for my 140A.
Josh
carsolha
Post by carsolha »
Ok. I need L-R- Off. I'll talk to him and let you know. Hopefully we'll get a few more.
