Tachometer
Tachometer
Post by 6277 »
My tachometer hour meter seems to be running slow. Today I flew 1.1 hobbs time and only .4 on the tach. Replace or rebuild? I like the looks of the tach and it seems to be orginal. Any ideas? 1947 Cessna 140 C-85-12F.
Re: Tachometer
Look on the back for a little hole that says "oil".
OTOH, the way they work, if the hours are slow the tach RPM indication should be too. Something to think about. Also, if you fly around at 1900 RPM the hours won't rack up as fast.
(Are you sure the Hobbs is accurate?)
Re: Tachometer
Post by 6277 »
Good points. I think the Hobbs is pretty much accurate, although I will double check it next time. I usually fly at 2400 RPM so at that RPM should the be at about 1:1? That is 1 hr of flight and 1 hour of tach time?
