Steel tie downs
Name: Horacio Berardone
Steel tie downs
Post by 5469 »
Hello,
I want to bring a set of tie downs from AircraftSpruce.
I see many models, with hammers, with corkscrew design and just steel construction welded or not.
What kit is suitable for a C140 ?
Weight is a factor, I am abandoning my old diy heavy ones.
Thanks a lot,
Horacio
Horacio Berardone Bouhébent
LV-NGL 1946 C140 SN 10.260.
Re: Steel tie downs
Post by 6843 »
The "Claw" is the only tie-downs that I've found to work in any soils I've encountered. I highly recommend them.
https://www.aircraftspruce.com/catalog/pspages/claw.php
Dave Sirota
'46 C-140 N89654
'96 Hatz N24B
KRYN
Aircraft Type: Cessna 120
Re: Steel tie downs
Post by 7950 »
I have these - they are easy to use and so far seem effective - although not used them in serious winds - importantly they store really easily and are light.
http://air-camp.co.uk/rootsystem1.html
6991
Occupation-Interests: Flight paramedic
Re: Steel tie downs
Post by 6991 »
The Claw has a really good record, and are easy to use. I always have a set in my plane.
Joe Belany
2470V
Name: John von Linsowe
Aircraft Type: 48 C-140
Occupation-Interests: CFI
Re: Steel tie downs
Post by 5806 »
I have two sets of "Claws". They go everywhere we may need to tie down at. Highly recommend them.
John
