Alternator conversion
Post by 8337 »
Hey Guys,
If I wanted to replace my generater (which apperantly is not working) with an alternator, what part or kit should I get? 1946 c140 with C-85.
Re: Alternator conversion
Post by 6896 »
I chose the 60A Alternator Conversion STC SA800NE from Barnstormers Aviation. Attached is the POC information for the STC and kit (voltage regulator is the one part offered in the kit) from the former club website. I don't know if the STC and kit are still offered, but this is what I purchased in 2006. The documentation and parts lists for the STC are excellent with details about the piece parts and alternatives for circuit breakers and other items.
alternator_considerations.pdf
(157.07 KiB) Downloaded 3133 times
STC SA800NE alternator installation on O-200 for c140.doc
(25 KiB) Downloaded 696 times
SA800NE altrnator install on C140.doc
(221 KiB) Downloaded 1213 times
ConsultEngr
8337
Post by 8337 »
Thank you
Search is your friend!
viewtopic.php?f=7&t=289
