Safety pins for cowl latches
8244
Aircraft Type: 120
Post by 8244 »
Where can I get stainless safety pins , of the correct size to secure the cowl latches on my 120 I prefer stainless steel but cadmium would be ok too. I believe it has standard latches as came from factory but will provide pictures if needed. Thanks in advance for your help
Re: Safety pins for cowl latches
Post by 5115 »
Look at Spruce for AN416-1 or -2, only the diameter differs between them.
Martin Tanguay
7313
Post by 7313 »
How are the safety pins used? Wheredo they attach?
When the old latches start to fail some folks do something like this....
But I went with the Davis option when my old latches failed....
5-27-11 033.jpg (123.87 KiB) Viewed 6215 times
7313 wrote: Sat Mar 30, 2019 12:03 pm How are the safety pins used? Wheredo they attach?
There is a "U" shaped bracket attached behind the lower part of the latch, near where the pin is in the photo above. The ends of the "U" are drilled and the pin goes through the holes and across the latch handle.
1567
Name: Matt and Carole Rybarczyk
Aircraft Type: 120
Post by 1567 »
You should fix the old latches properly, Univair has all the parts, or get the Davis mod STC from Ken and Lorraine Morris.
Matt
7313
Post by 7313 »
Leaning toward fixing up the originals.....
7313 wrote: Sun Mar 31, 2019 1:47 pm Leaning toward fixing up the originals.....
Even if you fix them up, the safety pins might still be a good idea.
5422
Aircraft Type: C-140, PA-18
Post by 5422 »
I copied this from another member can’t remember who. Anyway it will keep the latch from fully opening. Easy to make and I think they look good and I’ve never had the pins come out.
