SALE PENDING 1946 C140 (C-FJAR) $25000USD
Post by 5115 »
The process to re-import a US manufactured plane from Canada back to USA is not difficult. Don't let the North of the Border location stop yourself from considering it. :P
1946 CESSNA 140 Very well maintained, multiple STCs, flies regularly
Airframe TT: 3608 hours., Engine TTSO: 1243 hrs, STOH: 205 hrs
Engine: Continental 0-200 (STC) with 205 hours STOH (4 new Millenium cyl.). McCauley Prop 1A101 (69-48) as per Randy's STC with static at 2600rpm.
C150 Exhaust STC, MOGAS STC, Cowling latches STC
Brand new Harness and Slick Magnetos 4301with under 10 hrs on them. TAF-L Spin-on Oil Filter, 60 amp Alternator
McCauley wheels/brakes. Refurbished Scott 3200 tailwheel, new pressure plate, new chains/springs and new tire.
New Main tires and tubes.
Interior: C-150 newly upholstered seats with AeroFabric shoulder harnesses and belts (with STC) and new belt metal retaining bracket as per SB25-03. New carpets. Molded plastic interior restored (made for the C140), Hat shelve
Avionics : iCom A210 comm radio with integrated Intercom and Dual watch frequencies, King KT76A transponder with new transponder antenna
Instruments: Airspeed, Alti, VSI, Directional Gyro, AH, Turn Coordinator. Astrotech chrono, CHT, EGT, Oil temp (new), Oil Pressure, manifold pressure, Map light
Flown regularly. Annual inspection completed in May 2018.
Located in the Montreal, Canada region: look at airport CSA2
For more information, pictures and questions you can PM me. Many more pictures if you require
IMG_3284 - copie.jpg (196.05 KiB) Viewed 7083 times
IMG_3283 - copie.jpg (231.19 KiB) Viewed 7083 times
IMG_3280 - copie.jpg (206.34 KiB) Viewed 7083 times
Martin Tanguay
Re: For Sale 1946 C140 (C-FJAR) Has to go - Price Reduced!
Post by 5115 »
Price adjusted!
Thank you for looking!
Martin
Martin Tanguay
Post by 5115 »
Still for sale, spring is around the corner!.
Let me know if any questions.
Thank you for looking.
Martin Tanguay
Re: For Sale 1946 C140 (C-FJAR) $25000USD
Post by 5115 »
Just re-edited the ad. Still available and looking for a good home.
Get in touch for more information.
Martin Tanguay
Re: SALE PENDING 1946 C140 (C-FJAR) $25000USD
Post by 5115 »
After almost going back to the USA, FJAR found a new owner that should maintain and keep it alive for the following years.
It will be based at a 20 minutes flight from where we are presently.
Until final payment I'll enjoy a few more hours with it.
That was a great 11 years ride.
Martin Tanguay
