Timber packers around the fuel tank fillers, should these come right up to the underside of fabric, or sit just below?
Packers around fuel tank filler
7133
- Name: Michael Sheppard
- Occupation-Interests: Mechanical and Structural Designer.
Re: Packers around fuel tank filler
They support the fabric, which is glued to the wood.
Thanks John.
Seems logical but wanted to check.
Cheers
Michael
Cheers
Michael
Check your gas cap fit, before you install your fabric...........
