Original Battery Box Installation
Aircraft Type: Cessna 120
Post by 4290 »
Hello! Does anyone happen to have pictures of a very original battery box and installation? Figure 25 of the parts book shows the battery cables and solenoid on the front (forward) side of the box, but it seems like every installation I have seen has the cables and solenoid in the back (aft). Similarly, most of the battery boxes that I have seen with a hinged lid (like the one in the parts book) have the taller bottom side in the back vs. in front as depicted in the parts book.
Thanks in advance!
- John
Re: Original Battery Box Installation
This post shows the front and back of the battery box. The hinges on the front near the bottom do not have hinge pins. AN clevis pins are used to secure the box closed. The back of the box (high side, third photo) shows the mounting holes for the master solenoid and the holes for the cables.
VIP620
Name: ken tengesdal
Aircraft Type: 120
Post by VIP620 »
Post by 6298 »
I have always seen that solenoid on the back side. same battery box.
Looking closely at the IPC picture the arrow for the inset is pointing at the back side of the battery box installation.
I assume they used artistic license to turn the picture around for clarity for how the solenoid is mounted along with the wiring.
Just a guess.
On my bird, '46
5-25-12 006.jpg (228.57 KiB) Viewed 7516 times
I'm not even going to ask how you got that picture... ;)
8424
Name: Steve A H
Aircraft Type: 1950 C140A
Post by 8424 »
"I'm not even going to ask how you got that picture..."
Maybe a little bitty drone with a little bitty camera!
Steve
