140A Fuel dip stick
Aircraft Type: c140a
140A Fuel dip stick
Post by 8401 »
Does anybody know where I can find a dip stick for a 140A? Will a dip stick for a 150 work?
4390
Re: 140A Fuel dip stick
Post by 4390 »
viewtopic.php?t=232
You couldn't use a 150 stick since your 140 has a tailwheel and the 150 does not.
8292
Aircraft Type: C140A
Post by 8292 »
I use the 11" universal fuelhawk. I've run a tank to exhaustion ok two occasions and fueled the airplane a gallon at a time. I'm flying tomorrow, I'll try to remember to post my data.
John
Post by a64pilot »
All you need is a wooden dowel and mark it yourself.
However I learned to make it long enough that it can’t fall into the tank
a64pilot wrote: Sun Sep 20, 2020 10:34 am All you need is a wooden dowel and mark it yourself.
Good point Jody,
Primary student of mine did that a few months ago, and had to fish out the stick with some mechanical fingers that I picked up at Harbor Freight. To prevent a repeat, I put two 8" tie warps set at 180 degrees to each other at the top of the stick. Now if anyone lets go, the tie wraps prevent the stick from going down into the tank. Just my 2 cents.
Aircraft Type: Cessna 120
Post by 7896 »
Here is my sheet for a C120 and the 11" universal gauge. Not an exact match, but maybe helpful.
Cheers,
C120 - Fuel Hawk Calibration Curve.xlsx
(16.51 KiB) Downloaded 914 times
C120 - Fuel Hawk Calibration Curve.pdf
(303.16 KiB) Downloaded 1138 times
Michael Haas
'46 120 - N76219
Home Base: W96 (Quinton, VA)
