Looking to buy a used wood climb prop for a '46 140 C-85, have a metal standard prop now...looking to lose some weight and gain a little climb... Any leads appreciated.
Walt
WTB: Wood Climb Prop
8402
- Name: Walter L
Re: WTB: Wood Climb Prop
Can't sell you a prop, but, if performance is your goal, the extra weight of the metal prop is probably more than offset by the increase in efficiency.
8452
- Name: Larry B
- Occupation-Interests: Retired Automation Engineer, Nothing to do and all day to do it.
I thought that a wood prop in the correct pitch IS more efficient. The reason is the it effectively provides variable pitch.
Larry Bible
1966 Mooney M20F/J
1966 Mooney M20F/J
