Ethanol Free Gas
4390
- Name: Franklin B
Ethanol Free Gas
Does anyone run ethanol free gas (87 octane)? If so, do you like it? Any pireps? Good / bad?
Re: Ethanol Free Gas
Yes, and have since the EAA STC was issued "many" years ago. I do use 100LL probably every other fill-up & often end up with a blend. With pure auto fuel I notice a difference in idle (...believe the STC mentions this) as well as on start-up in cold weather...plus the auto fuel stinks
4006
- Name: Mike Gourd
- Occupation-Interests: Electrical & Electronic Design & Troubleshooting
I run it frequently. 100LL has more lead in it than Continental recommends. I probably average 75% mogas 25% 100LL. No issues to report. I have a
neoprene needle valve in my Stromberg carb and am aware of possible issues ( viewtopic.php?f=10&t=100 ) but have not experienced any problems, yet. I check my gas for ethanol, each time I buy it.
Mike Gourd, Centredale Airport CDL8
Only, about, 6000 hours on auto gas so far.
- Name: Franklin B
Well, I tried some Ethanol free gas and it seems to run just fine at full and cruise power but stumbles quite a bit from idles speeds to power, even quit a few times. Like the idle mixture is too lean now. Do I have to adjust the carb to run this gas?
I've so carefully filed my (EAA) STC that I can't put my hands on it right now...but, as I recall, there's mention that the "conversion" to using auto fuel may prompt need for idle mixture adjustment. Mac
...found it (The EAA STC "Flight Manual Supplement" in the 140 right where it's supposed to be
