I am doing the Annual Inspection on my 140 and have found fiberglass insulation behind the cabin panels.
It is not in good shape and looking through the IPC I cannot find any listed.
Is it something that has been added over the years or am I not looking in the right place?
Is it legal?
Is there a source for replacement?
Any information or suggestions would be helpful.
Insulation/Sound deadener
- Name: Rick F
- Aircraft Type: C-140 (sold)
Re: Insulation/Sound deadener
Get it out of there. It will hold moisture against the aluminum skin. Clean any corrosion that may have developed and prime the metal. Install closed cell vinyl-nitride foam in its place. It's available from places like Aircraft Spruce and is approved.
- Name: Rick F
Thanks John.
It didn't look right when I saw it.
Thankfully it was covered with cellophane to prevent moisture problems.
It is all coming out anyway.
