Where is your PTT button located? Photos?
I have used a Telex PTT that plugs in series with the headphone mic for years but am considering an installed push button on the new radio install.
Push To Talk button location
- 5806
- Name: John von Linsowe
- Aircraft Type: 48 C-140
- Occupation-Interests: CFI
Re: Push To Talk button location
I put one in the plastic hub of the pretzel yoke for a friend once. Sorry, no pictures...
- Name: Jeff T
- Aircraft Type: 48 140 C90
Send your email to colorfastinc@sbcglobal.net and i'll send some photos
I put mine just to the right of the throttle. I can push it with my hand on the throttle. Been that way for years..
I recently flew a friend's 140 with a momentary PTT toggle left of throttle (similar to Randy) -- surprised at how easy & natural it was to use with hand on the throttle (where it usually is?). Mac
- 7896
- Name: Michael Haas
- Aircraft Type: Cessna 120
Simple solution. Works well for me.
Michael Haas
'46 120 - N76219
Home Base: W96 (Quinton, VA)
'46 120 - N76219
8474
- Name: Blaine F
- Aircraft Type: C140A
Will tidy this up a bit when the airplane gets its new interior, but for now it works well.
- IMG_4347.jpeg (214.55 KiB) Viewed 12582 times
6352
- Name: Michael R
- Aircraft Type: 46 140 0-200
Mine are on the yoke, as above. But they were that way when I bought the plane. If I were to do it myself I would put it on the panel somewhere. Simple, no wires in cockpit. I used to rent a 150 that had that arrangement and adjusted to it quickly. KISS.
Mike Rabe
C140
KDVT
C140
KDVT
Mac & Randy,
can you post pictures of your ptt? I'd like to get a visual on it.
7836
- Name: Dane Pruitt
- Aircraft Type: C120
- Occupation-Interests: Airport Manager
Saline County Regional Airport - Contact:
