motorized tug
motorized tug
Post by 7103 »
Does any one use or know where to get a motorized tug for a C140
Aircraft Type: 48 140 C90
Re: motorized tug
Post by 6898 »
Lots out there most small powered ones start around $2800 ouch. Look for used in your area?
Re: motorized tug
I used to use a lawn tractor and a Wag Aero tailwheel tow bar. Cut the "T" off the handle and welded a ring on and pined it to a Bracket I made on the front of the tractor.
You cam probably pick up a tractor with a bum mower for a couple hundred bucks.
6974
Re: motorized tug
Post by 6974 »
I have a Minimax Tug and it works great. It is not the cheapest thing, but very easy to use.
hotrodmac
Re: motorized tug
Post by hotrodmac »
Thinking about building one of these. The cost of the commercial ones is waaay to high!!
http://www.vansairforce.com/community/s ... p?t=169376
‘53 C170B w/Avcon O-360
8244
Aircraft Type: 120
Re: motorized tug
Post by 8244 »
Would a pull handle installed work for you. It really works nice makes moving pretty easy.
