150 Exhaust STC
8474
Aircraft Type: C140A
150 Exhaust STC
Post by 8474 »
Does anyone have the contact info for Walter B Thomas, holder of STC SA648NE
Re: 150 Exhaust STC
Post by 8233 »
8474 wrote: Tue Sep 17, 2019 7:36 am Does anyone have the contact info for Walter B Thomas, holder of STC SA648NE
Actually, it's now owned by Ken & Lorraine Morris. More info here:
https://taildraggeraviation.com/stc-150-muffler-home/
Re: 150 Exhaust STC
An updated page in the "Resources" section of the Web Site should be available shortly.
8474
Re: 150 Exhaust STC
Post by 8474 »
Ok, thanks!
8322
Re: 150 Exhaust STC
Post by 8322 »
Not sure how it works, if theirs covers this or not, but when mine was done in 1980 they used the 150 setup that pulls heat off both sides... I know our gals have a reputation for low heat output... Mine with that set-up will cook you out...
8474
Re: 150 Exhaust STC
Post by 8474 »
Lorraine got right back to me and she has sent the STC. I'm planning on using the Wag-Aero kit https://www.wagaero.com/engine-parts/ex ... stems.html When I get around to doing the conversion. Although I have not seen the STC paperwork yet it looks to me like the one scat hose goes to the heater from one side and the other goes to the carb heat from the other side.
8482
Aircraft Type: '46 140
Re: 150 Exhaust STC
Post by 8482 »
8474 wrote: Wed Oct 02, 2019 9:42 am Lorraine got right back to me and she has sent the STC. I'm planning on using the Wag-Aero kit https://www.wagaero.com/engine-parts/ex ... stems.html When I get around to doing the conversion. Although I have not seen the STC paperwork yet it looks to me like the one scat hose goes to the heater from one side and the other goes to the carb heat from the other side.
This may be a redundant question but I need to be sure...This will fit on my O-200-A right?
Re: 150 Exhaust STC
8482 wrote: Tue Oct 15, 2019 11:29 am This will fit on my O-200-A right?
All C-series Continentals, including the O200, and I believe, all A-series Continentals, have the same exhaust port spacing.
Name: John von Linsowe
Aircraft Type: 48 C-140
Occupation-Interests: CFI
Re: 150 Exhaust STC
Post by 5806 »
8322 wrote: Tue Oct 01, 2019 10:18 am Not sure how it works, if theirs covers this or not, but when mine was done in 1980 they used the 150 setup that pulls heat off both sides... I know our gals have a reputation for low heat output... Mine with that set-up will cook you out...
Hello Raymond,
Curious if the carb heat is shared with cabin heat on one side?
John
Re: 150 Exhaust STC
Post by 5806 »
I would like to add a solution to a problem I had on my 0-200 exhaust installation. The baffling aluminum sheet wrapped around the mufflers have the clamping angle riveted to it. The thin aluminum would become deformed and the rivets would pull. I added a doubler under the angle that extended a couple inches around that baffling. I think these were obtained from Wag-Aero.
I might find a good photo of this and will post it.
John
