2020 Calendars in store
- 6898
- Name: Jeff T
- Aircraft Type: 48 140 C90
Go to store and under "Gear" calendars are now available.
6863
- Name: John Kliewer
Re: 2020 Calendars in store
So Jeff, are you telling me the reason I have not received a calendar is because I will need to buy one from the store if I want one?
John Kliewer
- Rob Swanland
- Name: Rob
- Aircraft Type: C-140A
- Occupation-Interests: Website & Forum Administrator
John, you will receive a calendar as an active member. Here is some further explanation for you and any other members that have not yet received the calendar... The calendars are mailed using USPS "bulk mail". The problem is that there is really no guaranteed delivery time for bulk mail. Unfortunately a small percentage of our bulk mail is delayed well past what seems reasonable. I have seen bulk mail delivered as late as 60 days after mailing. Next year we plan to mail the calendars well in advance of January 1 to adjust for the bulk mail timing problem. Now, back to your message, we are preparing a second mailing for those that did not have correct addresses in their member profile. We will make sure a calendar is mailed to you, via first class mail. Please do let us know when the original bulk mailed calendar finally shows up. Thanks for your patience... Rob
6863
Thank you Rob for the explanation. My address has not changed since I joined the Association so it should be the same as always.
John Kliewer
- 6898
- Name: Jeff T
John.Rob has explained it and I apologize for any confusion all 2020 members will receive a 2020 calendar.
6863
No problem Jeff. Thank you for your response and for your diligent work.
John Kliewer
I'm not sure what the pricing for "Bulk Mail" is, but maybe the Assn should look at "Media Mail" instead. It's a lot less than first class, and has been nearly as predictable for me. I think with Bulk mail the PO assumes zip code order, and if anything sticks together or is out of order it can get sent to the wrong corner of the globe.
OTOH, they seem to get those useless advertisements and political flyers out on time...
- Name: Blaine F
- Aircraft Type: C140A
Received my calendar yesterday in Canada, great job with the photos. It has a place of honour on my wall.
5469
- Name: Horacio Berardone
Hello,
I got my calendar last week in Buenos Aires.
Beautiful set of photographs !
Is in my living room african wenge book shelve !
Thanks a lot,
Horacio
Thanks a lot,
Horacio
Horacio Berardone Bouhébent
LV-NGL 1946 C140 SN 10.260.
