Master Cylinder Return Springs
Occupation-Interests: Mechanical and Structural Designer.
Post by 7133 »
I have an original Goodyear Master Cylinder with a broken return spring. Is it possible to buy these anywhere?
Michael
8306
Aircraft Type: C140A
Re: Master Cylinder Return Springs
Post by 8306 »
My plane had Goodyear master cylinders; I was told that parts are not available. Mine had a broken return spring, one piston shaft looked like it had been gouged up in a vise, and one filler plug was not vented. Oh, and there was a broken rudder pedal too. I had o/h'd Cleveland master cylinders installed, parts are readily available.
8306
Post by 8306 »
That being said, I do have the other intact Goodyear spring, if you still need it.
Or, I may know where you can get one. Let me know if you get stuck.
7981
Occupation-Interests: A&P /IA retired
Post by 7981 »
Try Prefered Air Parts
7981
Post by 7981 »
Also found GREAT Goodyear master cylinders at Smokin' Rivits A/C salvage. Very reasonable price also
