Headliner for 120
huck
Headliner for 120
I am looking for the bows and other hardware needed to mount a headliner in my 1946 Cessna 120. Not sure if all 120's have the two skylight windows but mine does so I also need the panels/trim rings not sure what they are called that hold the fabric of the headliner around each overhead window.
8474
- Name: Blaine F
- Aircraft Type: C140A
Re: Headliner for 120
I recommend getting Lorraine's video if you are going to tackle this job. http://skywardmedia.com/catalog.htm
The headliner itself is available from Airtex
huck
Thank you, I will check it out
