Trim Tab Actuator
Re: Trim Tab Actuator
John C » Fri Jul 20, 2007 10:18 am
My parts catalog is older than yours. ;)
Bob Tofsrud » Fri Jul 20, 2007 11:16 am
If the locknut (part no.16) is what locks part no.20 from turning it looks to me that you could still rotate the actuator 90 degrees and compensate by turning part no.20, 90 degrees also. or drill and tap new holes for the guard. It might require a little grinding if clearances inside get tight. Five hundred bucks would buy a little fuel.
Bob 2388N
7313
Trim Tab Actuator Repairs
Post by 7313 »
I found this old thread: viewtopic.php?f=14&t=775 that has a lot of good pictures and discussion about the various models of the actuator. My '46 120 has what I believe to be the original version, the same as is pictured in the old thread. There was a lot of discussion back then, and pictures of getting it apart, but no follow-on as to what parts were found worn and how to replace/repair them.
Does anyone have any experience with repair and reassembly?
Is it possible to reactivate this thread from the archives?
7313 wrote: Sat Oct 08, 2022 12:18 pm Is it possible to reactivate this thread from the archives?
Done
7313
Post by 7313 »
Thanks John. Do. You have any ideas re: worn parts or repairs for excessive play?
jwscholl
Post by jwscholl »
I am not sure, but believe it is true that this is same part used on Cessna 195 trim tabs….
The 195 Factory in New York rebuilds for 195s. Find on web.
Jon
5836
Occupation-Interests: Airbus QA Inspector
Post by 5836 »
McFarlane Aviation just posted they new PMAed units on sale. There is a breakdown of applicable P/N's by S/N for our 140's. They have a Core exchange discount for rebuilt units. (www.mcfarlaneaviation.com).
Clear Skies,
140 - N2287U
