Partial power loss
mikeacro
Occupation-Interests: Retired Corporate Pilot
Re: Partial power loss
Post by mikeacro »
Thanks for all the input. For sure though, it’s not the carburetor, because the problem only occurs on the right tank. I did find witness marks on the valve that indicated the right side was not full opening. I will check the finger strainer as recommended.
Mike
mikeacro
Post by mikeacro »
Also, is there a recommended way to remove the fuel selector valve. Special tools?
mikeacro
Post by mikeacro »
I do not have the vent interconnect
mikeacro wrote: Sun Mar 10, 2024 7:07 pm Also, is there a recommended way to remove the fuel selector valve. Special tools?
Double jointed wrists and lots of different wrenches.
Esmiol
Aircraft Type: C120
Post by Esmiol »
The restriction may not be large enough to show a difference but have you seen if you can see a difference in flow coming out the gascolator. Just time how long it takes to fill a quart or half gallon container. You could also separate the line to the gascolator to isolate it.
mikeacro
Post by mikeacro »
Yes, it took 2min and 4 seconds to drain a gallon from the gascolator when on the right tank ( the side I hade the problem ) and it took 1 minute and 21 seconds to drain a gallon with the left tank selected.
mikeacro
Post by mikeacro »
Also found a 20-30% blockage in the finger strainer on the right tank. Looked like carpet fuzz!
Esmiol
Aircraft Type: C120
Post by Esmiol »
Was the drain time pre or post “fuzz” removal? 81 vs 124 seconds is 53%, that’s a lot.
Aircraft Type: 140A/C90-14F
Post by 8413 »
1 gallon in 2min 4 sec should still be enough flow to not cause the engine to stumble. Even at full throttle the engine isn't burning anything close to that.
Josh
Well, there is less head pressure at the carb in full throttle climb than at the gascolator on the ground.
As a point of reference, an O200 will burn 11.1 gallons per hour at full throttle and rated RPM. A C85 is about 7.7 gallons per hour.
