Technical questioms
Technical questioms
I want to install all new bolts/hardware that attaches the engine mount to the fuselage. Can anyone give me the part numbers and where to order.
Re: Technical questioms
https://www.cessna120-140.org/member-on ... _hires.pdf
Should have what you need. I was able to use those numbers to get bolts from local suppliers.
- Name: Tamer A
The link to the hi-res partsbook above has been broken for a while now. Try this one:
https://cessna120140.com/wp-content/upl ... 120140.pdf
