Control tube (yoke)
monceaviation
Aircraft Type: 1946 140
Occupation-Interests: AP IA
Control tube (yoke)
Post by monceaviation »
Is there any place to get control tubes IPC fig. 19-33 page 39 (PN) 0411223. Or is it possible to get them re-chromed and have the correct outside diameter still? The ones that came with my plane are rusted pretty bad.
Re: Control tube (yoke)
Post by a64pilot »
I know that you can get almost anything rechromed, Not too long ago it was common to have cylinders chromed as a way to return them to new tolerances, so if a cylinder can be chromed to those exacting standards, surely a tube can.
I’ve run into two different types of chroming, the pretty stuff and it used to be that motorcycle shops “Harley type” were a good place to get things sent off to be chromed as they often have parts chromed, then there is hard chroming that’s I guess you would call an industrial process.
I think I would go the pretty route and if the tube is slightly larger, there is available as an STC what I believe are teflon balls to replace the ones in the instrument panel, they would be very simple to make the holes slightly larger.
I don’t think it would matter in this application, but I think that chroming can or will change the properties of the metal being plated, it makes it more brittle or something ?
I think I would try to find replacement tubes and send them off
Post by a64pilot »
Found this old thread, I’d go the titanium route myself under the using the concept of it exceeds original strength and fatigue resistance of the factory part.
viewtopic.php?f=7&t=926&start=10
On edit, Titanium can be polished to look like chrome and it stays that way, I have a Lightspeed bicycle from early90’s that is still highly polished.
I believe titanium actually oxidizes pretty much instantaneously and the oxidized layer is what keeps it from corroding.
It’s a Bitch to machine though, but drilling holes ought not be too bad.
Aircraft Type: C140A
Post by 8474 »
Just to update that previous thread, I was having no luck finding a shop here in Canada that was willing to do the work and the hard chroming required. Decorative chroming shops said that their chroming would not be suitable for this application. I did go with the titanium and had a machine shop cut it to length and drill the holes. I installed them using bolts instead of the OEM rivets. No issues at all so far.
