Floorboard inspection covers
Post by 8475 »
Hello everyone, my airplane has circular inspection covers on the floorboards just forward of the seats. I took them off and didn't see anything that might require inspection or service. Are these inspection holes common? Or was this a field mod for some reason?
Cessna 140 N76415 floorboard covers.jpg (307.31 KiB) Viewed 2675 times
2356
Re: Floorboard inspection covers
Post by 2356 »
Those are not original.
tonycondon
Post by tonycondon »
Mine has the same. My plane also had weld repairs done to the gear after a ground loop around 50 years ago. Perhaps put in for access?
N2395N
I had a mouse nest in there, now I have an inspection cover...
6643 wrote: ↑Fri May 06, 2022 3:40 pm I had a mouse nest in there, now I have an inspection cover...
Not original...........the only thing those access would be lost hardware when you're working on the rudder bars/brake master cylinders etc and loose hardware and it rolls down into that space where there "was" no access to get it out.........
Or........in John's case.........."Critter removal"
Post by 6298 »
I have one on the passenger side that I used to take pictures, back in the day when slides were the thing. Aerial Servey work..
