Accessory case cover for pull starter
dcannon
Aircraft Type: 1946 C120
Post by dcannon »
Call me crazy but I actually like hand propping. Starts first or second blade and feels more vintage. I think I'd rather have the weight savings and ditch my Delco Remy
Does an accessory case cover exist to cover a retired starter?
Aircraft Type: '46 140 0-200A
Re: Accessory case cover for pull starter
Post by 6597 »
6597 wrote: ↑Sat Apr 06, 2024 9:05 pm Fresno is your friend....
Interesting. They must have existed as the 120 was delivered with the same -12 engine less the starter and generator. But, as far as I can tell, neither the engine nor the airframe parts manuals list the cover.
dcannon
Post by dcannon »
Thank you David. "Pad" was definitely not in my search words. Always appreciate the help from the Association braintrust.
Post by 6597 »
Fresno had a vacuum pump pad cover (for when my pump finally dies on my 0-200, I carry it in the plane with tools and gasket/paste just in case). That's how I thought of the starter pad cover. Fresno has a bunch of oddball new-old-stock stuff. You are correct, not in the parts manual.
https://www.fresnoairpartsco.com/produc ... -pump-pad/
dcannon
Post by dcannon »
Do you prefer Permatex #3 on these cover gaskets?
8224
Post by 8224 »
I think it is perfectly ok to use your old gasket as a pattern and cut a cover plate out of .25” 2024T3 or 6061T6 aluminum plate. There is no direct oil pressure against it, only “splash” oil.
Steve Hawley
