AIRPLANE FLIGHT MANUAL's
8142
- Name: Stephen Driskell
I found these FLIGHT MANUAL's in the aircraft records and would like to now if the group would like to post these on the web site. I could email higher resolution for the ones that would be posted to the web site.
- CESSNA 140A (C-90) Flight Manual pg2 200.pdf
- (255.24 KiB) Downloaded 1861 times
- CESSNA 140A (C-90) Flight Manual pg1 200.pdf
- (276.88 KiB) Downloaded 1860 times
8142
Re: AIRPLANE FLIGHT MANUAL's
Here are the flight manual for the C140 with C85
- CESSNA 140 SKIPLANE (C-85) Flight Manual200.pdf
- (319.02 KiB) Downloaded 1085 times
- CESSNA 140 LANDPLANE (C-85) Flight Manual 200.pdf
- (281.74 KiB) Downloaded 1784 times
8424
- Name: Steve A H
- Aircraft Type: 1950 C140A
Hi Stephen.
Thanks for the 140A flight manual. I went thru all my paper work and didn't have it, and couldn't find it on the internet.
High res. copies would be great if you can get them posted to the site.
Steve A H
Steve A H
8474
- Name: Blaine F
- Aircraft Type: C140A
Yes, my thanks as well Stephan. I see it has been downloaded 25 times so there are a few of us that needed it.
8424
- Name: Steve A H
Stephen,
I sent you a PM referencing the C140A airplane Flight Manual.
Steve A H
Steve A H
a64pilot
- Name: Jody
Does anyone know if the propellor avoid range of 1950 to 2170 for the metal prop is for all metal props, or just the Mcauley?
Restricted ranges are prop specific. The McCauley restriction was lifted by McCauley SB13.
http://www.skyportservices.net/McCSB13.htm
a64pilot
- Name: Jody
Thanks, it could have been an engine resonance range, and or the combination of engine / prop.6643 wrote: ↑Sun Jan 03, 2021 10:59 am Restricted ranges are prop specific. The McCauley restriction was lifted by McCauley SB13.
I thought avoid ranges for a two blade were unusual, and I had not been avoiding those RPM’s in fact I’d say I’m in them most approaches, to say nothin of the 1800 RPM run up RPM.
Four blades and more due to reactionless mode are common, and really, really need to be adhered to.
So there are NO RPM avoid ranges?
I wondered why no yellow range on the tach.
The plane was originally certified with a wooden prop, so no restricted range on the tach. When the McCauley prop became available, McCauley issued SB-12 listing the restricted range and adding a placard to the panel. (I have been unable to scare up a copy of SB-12). SB-13 rescinded SB-12, so the placard can come off.
- Name: John Kliewer
There is a yellow arc on my tachometer for my C-90 which I have been respecting in the 13+ years I have owned the airplane. Has the restriction been rescinded for the C-90 as well?
John Kliewer
